Altair HyperMesh
New Features
- FMVSS201 U Tool
- The Upper Interior Head Impact tool is now available in the LS-DYNA interface. Refer to the Safety Tools release notes for more information.
Enhancements
- New Supported Keywords
- The following keywords are now supported:
- *BOUNDARY_SPC_SYMMETRY_PLANE
- *DATABASE_BINARY_INTFORC_FILE
- *MAT_HOT_PLATE_ROLLING
- Updated Keywords for LS-DYNA R14.0
- New attributes or attribute values have been added to the following
keywords for LS-DYNA R14.0 manual:
- *CONSTRAINED_RIGID_BODIES, *CONSTRAINED_INTERPOLATION_SPOTWELD
- *CONTROL_RIGID, *CONTROL_OUTPUT, *CONTROL_TIMESTEP, *CONTROL_SOLID, *CONTROL_IMPLICIT_SOLVER, *CONTROL_CONTACT, *CONTROL_CPM
- *DEFINE_CPM_NPDATA
- *MAT_ADD_COHESIVE, *MAT_ADD_DAMAGE_DIEM, *MAT_ANISOTROPIC_ELASTIC_PLASTIC, *MAT_LAMINATED_COMPOSITE_FABRIC, *MAT_TABULATED_JOHNSON_COOK, *MAT_COHESIVE_MIXED_MODE_ELASTOPLASTIC_RATE
- *SENSOR_CONTROL, *SENSOR_DEFINE_MISC, *SENSOR_SWITCH_SHELL_TO_VENT
- Deletion of Position Entities (*DEFINE_TRANFORMATION)
- When deleting a Position entity (*DEFINE_TRANFORMATION), you are asked
to choose if the impacted nodes have to be moved to their original
position, or, if they have to be maintained in the transformed
position.
- Contact Penetrations Check
- The multiple LS-DYNA MPP output files are now considered in the process of reading penetrations from solver output files.
Resolved Issues
- More than one line in *DATABASE_TRACER is now supported.
- Curves attributes OFFA and OFFO are now considered in unit conversion process.
- Include files defined in INCLUDE_TRANSFORM are now correctly exported in the folder defined by INCLUDE_PATH.
- Attribute IDGRP in *DEFINE_ELEMENT_DEATH_(OPTION) is now correctly supported as an integer.
- A correction has been made in the model import process when a model has an INCLUDE_TRANSFORM referencing an undefined include file.
- Constraint entity IDs offsets, defined with IDROFF in INCLUDE_TRANSFORM, are now correctly applied.
- A correction in the model import process for *INITIAL_STRESS_BEAM which were failing in some use cases has been made.
- A correction in the model export process when option DBOX is defined in *SET_SEGMENT_GENERAL has been made. The option DBOX wasn't always exported correctly.
- A correction in the model import process for *INCLUDE_TRANSFORM with IDs Offsets referencing nested include files has been made.
