Altair HyperMesh
New Features
- Seat Foam Deformer
- The Seat Foam Deformer tool has been added in the PAM-CRASH interface. Refer to the Safety Tools release notes for more information.
- FMVSS201 U Tool
- The Upper Interior Head Impact tool is now available in the PAM-CRASH interface. Refer to the Safety Tools release notes for more information.
Enhancements
- PAM-CRASH 2023 Profile Support
- Support of PAM-CRASH 2023 profile has been added.
- Keyword Updates
- The following keyword updates have been made per PAM-CRASH 2023 manual:
- The CNTAC_INTERSECTION option has been added to CKCTRL/.
- The SHELL_ORTHO_FRAME, ELEMENT_ELIMINATION_CYCLE, and ELEMENT_ELIMINATION_TIME options have been added to ECTRL/.
- For ECTRL/, a new element control 'Beam mass' in implicit analysis has been added.
- A new qualifier has been added to mass matrix assembly in EIGEN/.
- For PRCTRL/, a new block has been added to control the output during solution phase.
- For PRCTRL/, CNTAC_GEOM and new options have been added to control print of GROUP/.
- For TCTRL/, new keyword PYRA5_TIMESTEP and AUTO_INCREMENT_STRAIN_RATE have been added.
- The NUMPAR/ keyword has been updated with the following options: SECTION_INTEGRATION, MIDPLANE_INTEGRATION, BEAM_TORSIONAL_LUMP_INERTIA, ORTHO_FRAME_UPDATE, FAILED_SECTION_RATION
- Safety keyword BAGIN - FPM(FPM_GASDYN) have been updated with new options.
- Belt Retractor Pretensioner Definition updated as per new manual.
- Group Entity Selections Improvements
- From the context menu of set selector, a set can also be created using
EDG Elements by selecting Faces, Facets, or Edges in the microdialog and
creating those elements simultaneously.
- Elements ID Pool Improvements
- Added Individual ID pools for RBODY, LINCO, MTOCO, and OTMCO elements to avoid renumbering on import when duplicated IDs exist.
- Deletion of Position Entities
- When deleting a Position entity, you are asked to choose if the impacted
nodes have to be moved to their original position, or, if they have to
be maintained in the transformed position.
- Contact Penetrations Check
- The Penetration Check tool now has a new and simplified workflow. Refer to the General release notes.
