Altair HyperMesh
New Features
- FMVSS201 U Tool
- The Upper Interior Head Impact tool is now available in the Radioss Interface. Refer to the Safety Tools release notes for more information.
Enhancements
- Radioss 2024 Profile Support
- Support of Radioss 2024 profile has been added.
- Updated Keywords for Radioss 2023.1
- New attributes or attribute values have been added to the following
keywords for Radioss 2023.1:
- /FAIL/FABRIC
- /PROP/TYPE14
- Updated Keywords for Radioss 2024
keywords to Radioss 2024:
- /PROP/TYPE9, /PROP/TYPE10, /PROP/TYPE11, /PROP/TYPE16, /PROP/TYPE17, /PROP/TYPE19, /PROP/TYPE51
- /PLY
- /STACK
- Deletion of Position Entities
- When deleting a Position entity, you are asked to choose if the impacted
nodes have to be moved to their original position, or, if they have to
be maintained in the transformed position.
- Contact Penetrations Check
- The Penetration Check tool now has a new and simplified workflow. Refer to the General release notes.
- Performance Improvements
- Performance is improved in the model export process, when a high number of nodal masses (/ADMAS Type 5) are defined in the model.
Resolved Issues
- The issue when creating /ADMESH/GLOBAL keyword has been resolved.
- A correction in the model import process related to /GRNOD/BOX keyword has been made.
- A correction in the model import process related to ANIM/SHELL/IDPLY keywords has been made.
- A correction in the model export process related to /H3D/LSENSOR keyword has been made.
- Second order tetra elements are now selectable in /TH/BRIC.
