NFX-T: 1005 Simple Two Phase Gearbox
Set up a simple two phase gearbox for drive train oiling simulation using SimLab for CFD-nanoFluidX solution.
Note: A PDF version of this tutorial is available in the Model Files section.
In this lesson you will learn how to:Figure 1.
- Select Unit System
- Import CAD Geometry
- Define SPH Flow Solution
- Define Air and Oil Properties
- Define Initial Conditions
- Define Body Force
- Assign Motion
- Create SPH Particles
- Check Solver Settings and Result Request
Prerequisites
To run this simulation, you will need access to a licensed version of SimLab and nanoFluidX.
Model Files
Before you begin, copy the file(s) used in this tutorial to your
                    working directory.
        Tutorial Video
Additional Resources
For more tutorials, visit the SimLab Learning Center.
