Manufacturing Solutions
Unified environment for manufacturing process simulation, analysis, and design optimization.
HyperForm
- Benefits
                            - Introduces forming feasibility criteria early in product development, where the most significant improvements are possible
- Accurately predicts the blank size for improved material utilization
- Minimizes material wastage via blank nesting
- Provides a powerful tool to modify and verify multiple process scenarios with the ability to record and reuse complex model setup for repeatability of best practices
- Visualizes wrinkles and splits, and fixes problems before cutting any steel
- Provides an automated approach for optimization of the stamping processes
- Model setup for tailor welded blank and layered blanks
- Springback positioner and compensation – Positions the part after springback relative to tools based on user preferences and compensates the tool for springback.
- Model setup for warm forming, Hot stamping, composite forming, and thermoplastic forming process.
- Model setup for forming tubes: Tube Bending, Tube Preforming, and Tube Hydroforming.
- New GUI to quickly set up optimization problems in sheet metal forming
- Die stress analysis and die topology optimization from predicted forming forces.
- Drastically reduces the overall product cycle.
For more information, reference the Manufacturing Solver help manual.
HyperXtrude User Profile
The HyperXtrude user profile under Solver Interfaces provides an interface for the HyperXtrude solvers for metal extrusion, polymer processing, and binder jet sintering. This also serves as the backend meshing and model setup engine for the Inspire interfaces of these solutions. These Inspire interfaces for manufacturing solvers feature a high level of automation that enables them to go from CAD to the solution. For advanced models that are not supported by this automation and when the meshing automation fails, you can complete the model setup in HyperMesh using this profile. Refer to the Solvers section of this introduction for more details about these solvers.
HyperMold
- Moldex3D Solid
- Moldex3D Shell
- Moldflow (Midplane, Fusion, and Solid 3D)
- HyperXtrude for Resin Transfer Molding
- Moldex3D
- This user profile supports model setup for three-dimensional injection
                            molding simulations using Moldex3D Solid Solver.- Benefits
                                        - Easy-to-use meshing wizards for model creation
- Support for standard and fast cool analysis
- Model diagnostics (similar to the solver)
- Moldflow
- This user profile supports model setup for injection molding simulations
                            using Autodesk® Simulation Moldflow® software.- Benefits
                                        - Support for Midplane, Fusion (dual domain), and Flow3D analysis
- Easy-to-use wizards to set models for all three model types
- Model diagnostics includes fusion mesh match estimator
- Tools to create runner system and cooling circuits
- RTM
- Use this interface to set up models for resin transfer molding analysis. This also serves as the backend model setup engine for Inspire RTM. This Inspire interface features a high level of automation that enables it to go from CAD to the solution. For advanced models that are not supported by this automation and when the meshing automation fails, you can complete the model setup in HyperMesh using this profile.
HyperWeld
HyperWeld provides an efficient interface for setting up models for friction stir welding analysis. This user profile serves as the backend model setup engine for our recommended Inspire Friction Stir Welding. This Inspire interface features a high level of automation that enables them to go from CAD to the solution. For advanced models that are not supported by this automation and when the meshing automation fails, you can complete the model setup in HyperMesh using this profile.
Results Mapper
- Benefits
                            - Incorporates the manufacturing effects into structural analysis
- Open environment that allows mapping of data between arbitrary solvers
