Altair HyperGraph 2024 Release Notes
General
Announcements
Starting with version 2024, HyperGraph will no longer directly support AcuSolve log files. HyperMesh CFD will be the solution for supporting all CFD related workflows in the HyperMesh environment, including AcuSolve results.
Enhancements
- Define Curves
- The Define Curves panel has been migrated to a dialog that also includes a built-in Expression Builder.
- Python API
- The Python API has been expanded for HyperView and HyperGraph. For standard HyperView plotting (Notes, Sections) and the HyperGraph Line Chart (XY curve import for single/multiple files, complex curves, query plot files channels as NumPy/Pandas arrays) have been updated:
- Command Recording
- HWC (HyperWorks Command language) coverage, which allows you to record and playback workflows in HyperView, has been improved with a performance mode.
- Other Enhancements
                        - In the Notes microdialog, the Snap
                                    to option has been implemented, which positions the
                                note by snapping it to the curve.Figure 5.
 Figure 6.
Resolved Issues
- Application crash while reading an elout file from LS-DYNA.
- Issue with dynamic results plotting in HyperGraph while a solver was running.
- Python script submission using the File menu.
- Additional bug fixes.
Solver Interfaces
EDEM Interface
Post-processing Enhancements
- Support for EDEM HDF5 results.
PAM-CRASH 2G Interface
- Support for PAM-CRASH retractor entity in an ERFH5 file.
Radioss Interface
- Support for reading sensor data in Radioss time history files.
- Support for new variables vx, vy, vz, ssp, and mach for Radioss BRIC.
- Support for new Radioss beam outputs.
- Support for a new time history option in Radioss (/TH/SPH_FLOW).
Extensions
Enhancements
- autoLoad
- The new autoLoad entry can be used to load the extension automatically when the extension is added. This will replace the deprecated extends entry.
- unloadable
- The new unloadable entry can be used to disable the unloading of the
                                extension:Figure 7.
- Support for Custom Documentation
- Enhanced support for custom documentation is now supported for scripted contexts. Using the F1 key can be linked to the documentation packaged with the extension.
- MacToExtension Tool
- The command-line utility MacToExtension tool will convert a HyperMesh
                            macro menu file (.mac) to an extension. Once the
                            extension is loaded, a new menu will be created with the extension
                                name.Note: This tool will provide a functional drop-down menu with a flat hierarchy. To have a polished extension, additional work is required.
