Create Channels
Create or import channels (load histories).
Add Time Data Loads
Click the Load Map tool.
The Load Map dialog opens. - Select Time Data from the Channel Type drop-down menu in the top-left of the dialog.
In the Choose file field, click
and browse for
files.
Accepted file formats are: .rpc/.rsp, .csv, and .dac -
Click
to add the load
case(s).
- Optional: Edit the maximum and minimum values of the loads.
- Optional:
Click
to
view a plot of the load.
Add Constant Amplitude Loads
Figure 3.
The Load Map dialog opens. - Select Constant Amplitude from the Channel Type drop-down menu in the top-left of the dialog.
Click
to add the load case.
Tip: Click in the Channel Name field to rename the load case. - Optional: Edit the maximum and minimum values of the load.
- Optional:
Click
to
Figure 4.
Add Block Loads
Block loads are available for the Time Series loading type. Figure 5. Sample CSV Format
Figure 6.
The Load Map dialog opens. - Select Block Loading from the Channel Type drop-down menu in the top-left of the dialog.
Click
The Block Load dialog opens. -
Specify a name for the block load.
Specify the number of blocks to create then
Edit the values for Max Amplitude, Min Amplitude, and Cycles.
Different blocks come together to make a block sequence, which is used for the damage calculation.
Click Create.
Figure 7.
Tip:
- Use the
and
icons to import and
export block load .csv files. - Select a block and click
to delete it. - To exclude a block from the load, disable its checkbox.
