Create Materials
Create new materials and define their properties.
The materials available and their corresponding properties are based on the fatigue module that you select. If SN or Weld is selected, materials with SN properties are listed. If EN is selected, materials with EN properties are listed.
Note: Unlike OptiStruct, materials in HyperLife are defined by stress amplitude by default.
Click the tool.
The Assign Material dialog opens. -
Create a new material with reference to an existing material.
Create a material from scratch.
Note: Changing the units automatically updates the material properties and magnitudes
accordingly.
Note: Refer to Fit a Curve by Estimating UTS
and Other Methods for Fitting a Curve to define EN
properties.
