| Tensile Strength
Listed in SN tab (default = 300 N/mm2) |
| Yield Strength
Listed in SN tab (default = 180 N/mm2) |
| Elastic Modulus
Listed in SN tab (default = 2e5 N/mm2) |
| Strain At Break Point (A%) |
Listed in SN tab (default = 10% or 0.1) |
| Normal Fatigue Limit
Listed in SN tab (default = 140 N/mm2) |
| Shear Fatigue Limit
Listed in SN tab (default = 80 N/mm2) |
| Number of Cycles at Knee Point, Normal Stress
Listed in SN tab (default = 1e6 cycles) |
| Number of Cycles at Knee Point, Shear Stress
| SN curve slope, Normal Stress
Listed in SN tab (default = 5) |
| SN curve slope, Shear Stress
Listed in SN tab (default = 8) |
| Fatigue Stress Factor, Fully Reversed, Normal
Listed in Other tab (default = 0.4) |
| Fatigue Stress Factor, Fully Reversed, Shear
Listed in Other tab (default = 0.577) |
| Constant, Technological Size Factor for Tensile Strength
Listed in Other tab (default = 0.15) |
| Constant, Technological Size Factor for Yield Strength
| Constant, Technological Size Factor @ adm
Listed in Other tab (default = 40mm) |
| Non-linear Strain Stress Factor under bending –
Listed in Other tab (default = 1.0) |
Constant for (
) ratio for Fatigue Strength Factor (
Constant for (
) ratio for Fatigue Strength Factor (\
Listed in Other tab (default = 2400) |
| Constant For Roughness Factor, Normal Stress
Listed in Other tab (default = 0.22) |
| Minimum permissible tensile strength constant
Listed in Other tab (default = 400 N/mm2) |
| Constant for Mean Stress Sensitivity
Listed in Other tab (default = 0.35) |
Listed in Other tab (default = -0.1) |
| Compression Strength Factor, for tension, compression
| Compression Strength Factor, Shear
| Material Parameter Epsilon_0 (Epsilon_0) |
Listed in Other tab (default = 0.05) |
| Ductility factor (q) |
Listed in Other tab (default = 0) |
