Define the models, input variables, and output responses to be used in the
study.
A Definition is used in the Setup and approaches to define the models, input
variables, and output responses used in the study. When creating an approach, you
can choose to clone the Definition that was defined in either the Setup or an
existing approach.
Review the status of a Definition to verify that each step is
complete.
Go to the Definition step.
Click the Status tab.
The work area
displays a status of each step in the Definition.
Navigate to a step in the Explorer by
clicking Review from the Navigate column.
Compare definitions
Compare a Definition with others in the study to identify which are
identical or different.
Click the Compare tab.
The work area
displays a list of Definitions in the study, and indicates
which are identical or different.
From the Compare to: column, click
Identical or
Different.Figure 2. The Compare Definitions dialog opens.
A list of the different types of channels used in the study is
displayed, along with a count of all instances found to be
identical and different.
Click a channel to display a detailed comparison.Figure 3.
