By default, all input variables imported or manually added to your study are made
active. Make an input variable inactive so that it is no longer an independent
variable.
Reducing the number of independent variables can reduce the number of runs required
in an Optimization or DOE
approach.
In the Define Models step, Active column, clear the input variable's
corresponding checkbox.
