Sampling Fit Output Files
Output files generated from the a Sampling Fit.
<samplingfit_variable_name>_anova.dat
- File Creation
                        This file is created upon saving the study if Least Squares approximations have been created.
- File Location
- <study_directory>/approaches/<samplingfit_variable_name>/<samplingfit_variable_name>_anova.dat
- File Contents
                        Result Format Description ANOVA ASCII The analysis of variance (ANOVA) results are given in table form for each response approximation.
<samplingfit_variable_name>_approximations.slk
- File Creation
- This file is created upon saving the study if Least Squares approximations have been created.
- File Location
- <study_directory>/approaches/<samplingfit_variable_name>/<samplingfit_variable_name>_approximations.slk
- File Contents
                            Result Format Description Regression Excel Spreadsheet that holds the response surface created in the approximation. Use this file to make trade-off studies by modifying the Current Value of each input variable. It also contains sensitivity information.
<samplingfit_variable_name>.hstds
- File Creation
- This file is created when Apply is selected during the Specifications step.
- File Location
- <study_directory>/approaches/<samplingfit_variable_name>/<samplingfit_variable_name>.hstds
- File Contents
                            Result Format Description Run Matrix Data hstds, binary Hstds files stores the retained data sources; direct access data using the .hstds file is not suggested.
<fit_variable_name>.hstdf
- File Creation
- File Location
- <study_directory>/approaches/<samplingfit_variable_name>/<samplingfit_variable_name>.hstdf
- File Contents
                            Result Format Description Run Matrix Data hstdf, binary Hstdf files store the run data; however, direct access to the data using the hstdf files are not suggested.
