Stochastic Output Files
Output files generated from the a Stochastic.
<sto_variable_name>.hstds
- File Creation
- This file is created when Apply is selected during the Specifications step.
- File Location
- <study_directory>/approaches/<sto_variable_name>/<sto_variable_name>.hstds
- File Contents
                            Result Format Description Run Matrix Data hstds, binary Hstds files stores the retained data sources; direct access data using the .hstds file is not suggested.
<sto_variable_name>.hstdf
- File Creation
- File Location
- <study_directory>/approaches/<sto_variable_name>/<sto_variable_name>.hstdf
- File Contents
                            Result Format Description Run Matrix Data hstdf, binary Hstdf files store the run data; however, direct access to the data using the hstdf files are not suggested.
