Attach/Detach Parameters from Existing Parameters
From the menu bar, click .
The Editor opens.
- In the File field, open the file to be used as the base input template.
Attach/detach parameters.
Option Description Attach parameters to existing parameters Highlight the appropriate fields in the text area, then right-click and select context menu. from theDetach parameters from existing parameters Highlight the parameter to detach in text area, then right-click and select context menu. from theor
In the row that contains the parameter to detach, click
and select from the context menu.
