Examples
Static Analysis
Transient Analysis
Complex Results
Element Results with Layers and ID Pool
2D Tensor Result with Corner Data
Results in Element System
Delimiter and Animation Source
Include File
HWASCII File
ALTAIR ASCII FILE
$SUBCASE = 1 "SUBCASE 1 = ls "
$BINDING = NODE
$COLUMN_INFO = ENTITY_ID
$RESULT_TYPE = Displacement(v)
1 2.675570E-04 -1.055090E-04 0.000000E+00
2 2.507720E-04 -9.883090E-05 0.000000E+00
3 2.440140E-04 -8.849120E-05 0.000000E+00
4 2.400880E-04 -7.778800E-05 0.000000E+00
5 2.382920E-04 -6.713340E-05 0.000000E+00
6 2.381860E-04 -5.667990E-05 0.000000E+00
7 2.399790E-04 -4.656910E-05 0.000000E+00
8 2.440990E-04 -3.715890E-05 0.000000E+00
9 2.569460E-04 -3.123160E-05 0.000000E+00
10 2.378820E-04 -9.724510E-05 0.000000E+00
11 2.261050E-04 -8.938470E-05 0.000000E+00
12 2.183770E-04 -8.228280E-05 0.000000E+00
13 2.144560E-04 -7.396890E-05 0.000000E+00
14 2.126330E-04 -6.531210E-05 0.000000E+00
15 2.126250E-04 -5.672990E-05 0.000000E+00
16 2.144460E-04 -4.859660E-05 0.000000E+00
17 2.194190E-04 -4.158990E-05 0.000000E+00
18 2.270470E-04 -3.354960E-05 0.000000E+00
19 2.065580E-04 -9.435890E-05 0.000000E+00
20 1.993960E-04 -8.558060E-05 0.000000E+00
21 1.931290E-04 -7.805470E-05 0.000000E+00
22 1.891980E-04 -7.077870E-05 0.000000E+00
23 1.874210E-04 -6.327090E-05 0.000000E+00
24 1.873940E-04 -5.576850E-05 0.000000E+00
25 1.892170E-04 -4.847780E-05 0.000000E+00
26 1.927070E-04 -4.088540E-05 0.000000E+00
27 1.963510E-04 -3.220370E-05 0.000000E+00
28 1.759030E-04 -9.295610E-05 0.000000E+00
29 1.714210E-04 -8.391900E-05 0.000000E+00
30 1.669840E-04 -7.588670E-05 0.000000E+00
31 1.637570E-04 -6.845360E-05 0.000000E+00
32 1.621190E-04 -6.121470E-05 0.000000E+00
33 1.620260E-04 -5.397270E-05 0.000000E+00
34 1.632340E-04 -4.653920E-05 0.000000E+00
35 1.651600E-04 -3.857390E-05 0.000000E+00
36 1.665810E-04 -2.973420E-05 0.000000E+00
37 1.458880E-04 -9.218070E-05 0.000000E+00
38 1.430520E-04 -8.302430E-05 0.000000E+00
39 1.400460E-04 -7.461920E-05 0.000000E+00
40 1.376770E-04 -6.679290E-05 0.000000E+00
41 1.363570E-04 -5.926470E-05 0.000000E+00
42 1.361240E-04 -5.175800E-05 0.000000E+00
43 1.367060E-04 -4.401210E-05 0.000000E+00
44 1.375140E-04 -3.578490E-05 0.000000E+00
45 1.376660E-04 -2.693740E-05 0.000000E+00
46 1.163350E-04 -9.165220E-05 0.000000E+00
47 1.145410E-04 -8.242320E-05 0.000000E+00
48 1.125730E-04 -7.372090E-05 0.000000E+00
49 1.109470E-04 -6.547520E-05 0.000000E+00
50 1.099700E-04 -5.749100E-05 0.000000E+00
51 1.096870E-04 -4.954260E-05 0.000000E+00
52 1.098490E-04 -4.143300E-05 0.000000E+00
53 1.099740E-04 -3.298910E-05 0.000000E+00
54 1.094280E-04 -2.416260E-05 0.000000E+00
55 8.707490E-05 -9.123270E-05 0.000000E+00
56 8.596180E-05 -8.194280E-05 0.000000E+00
57 8.472750E-05 -7.300680E-05 0.000000E+00
58 8.367890E-05 -6.438790E-05 0.000000E+00
59 8.301700E-05 -5.595380E-05 0.000000E+00
60 8.277160E-05 -4.753820E-05 0.000000E+00
61 8.277980E-05 -3.901260E-05 0.000000E+00
62 8.259080E-05 -3.037550E-05 0.000000E+00
63 8.172000E-05 -2.153050E-05 0.000000E+00
64 5.798220E-05 -9.089970E-05 0.000000E+00
65 5.733730E-05 -8.155900E-05 0.000000E+00
66 5.662390E-05 -7.244890E-05 0.000000E+00
67 5.600950E-05 -6.354170E-05 0.000000E+00
68 5.561270E-05 -5.473560E-05 0.000000E+00
69 5.545660E-05 -4.589810E-05 0.000000E+00
70 5.544530E-05 -3.692350E-05 0.000000E+00
71 5.538980E-05 -2.783880E-05 0.000000E+00
72 5.446080E-05 -1.907040E-05 0.000000E+00
73 2.897410E-05 -9.067840E-05 0.000000E+00
74 2.867840E-05 -8.130300E-05 0.000000E+00
75 2.835350E-05 -7.208490E-05 0.000000E+00
76 2.807260E-05 -6.299480E-05 0.000000E+00
77 2.789020E-05 -5.394220E-05 0.000000E+00
78 2.782200E-05 -4.479850E-05 0.000000E+00
79 2.783480E-05 -3.543620E-05 0.000000E+00
80 2.784510E-05 -2.573960E-05 0.000000E+00
81 2.789890E-05 -1.584560E-05 0.000000E+00
82 2.903350E-04 -1.291340E-04 0.000000E+00
83 2.781780E-04 -1.101870E-04 0.000000E+00
84 2.705260E-04 -9.483520E-05 0.000000E+00
85 2.665760E-04 -8.126120E-05 0.000000E+00
86 2.646720E-04 -6.848620E-05 0.000000E+00
87 2.645070E-04 -5.604280E-05 0.000000E+00
88 2.661590E-04 -4.349700E-05 0.000000E+00
89 2.710040E-04 -3.002200E-05 0.000000E+00
90 2.793670E-04 -1.444070E-05 0.000000E+00
91 0.000000E+00 -9.059880E-05 0.000000E+00
92 0.000000E+00 -8.121120E-05 0.000000E+00
93 0.000000E+00 -7.195480E-05 0.000000E+00
94 0.000000E+00 -6.279930E-05 0.000000E+00
95 0.000000E+00 -5.365590E-05 0.000000E+00
96 0.000000E+00 -4.439450E-05 0.000000E+00
97 0.000000E+00 -3.485870E-05 0.000000E+00
98 0.000000E+00 -2.488340E-05 0.000000E+00
99 0.000000E+00 -1.390980E-05 0.000000E+00
100 3.489630E-04 -1.501470E-04 0.000000E+00
101 3.287750E-04 0.000000E+00 0.000000E+00
102 2.898680E-04 -1.155390E-04 0.000000E+00
103 2.721430E-04 -2.067990E-05 0.000000E+00
104 2.471570E-04 -1.081430E-04 0.000000E+00
105 2.315090E-04 -2.305800E-05 0.000000E+00
106 2.114200E-04 -1.047150E-04 0.000000E+00
107 1.972640E-04 -2.214240E-05 0.000000E+00
108 1.786880E-04 -1.029570E-04 0.000000E+00
109 1.658830E-04 -2.010520E-05 0.000000E+00
110 1.475890E-04 -1.019460E-04 0.000000E+00
111 1.362260E-04 -1.761070E-05 0.000000E+00
112 1.174250E-04 -1.012740E-04 0.000000E+00
113 1.076760E-04 -1.505010E-05 0.000000E+00
114 8.778540E-05 -1.007790E-04 0.000000E+00
115 7.984900E-05 -1.258870E-05 0.000000E+00
116 5.842140E-05 -1.004110E-04 0.000000E+00
117 5.245600E-05 -1.009330E-05 0.000000E+00
118 2.918660E-05 -1.001770E-04 0.000000E+00
119 2.542870E-05 -7.723280E-06 0.000000E+00
120 0.000000E+00 -1.000940E-04 0.000000E+00
121 0.000000E+00 0.000000E+00 0.000000E+00
$BINDING = NODE
$RESULT_TYPE = Rotation(v)
1 0.000000E+00 0.000000E+00 -1.806490E-05
2 0.000000E+00 0.000000E+00 -1.170600E-05
3 0.000000E+00 0.000000E+00 -5.260080E-06
4 0.000000E+00 0.000000E+00 -3.344090E-06
5 0.000000E+00 0.000000E+00 -1.252660E-06
6 0.000000E+00 0.000000E+00 7.145260E-07
7 0.000000E+00 0.000000E+00 2.250660E-06
8 0.000000E+00 0.000000E+00 7.860970E-06
9 0.000000E+00 0.000000E+00 1.204470E-05
10 0.000000E+00 0.000000E+00 -7.530430E-06
11 0.000000E+00 0.000000E+00 -8.588370E-06
12 0.000000E+00 0.000000E+00 -5.613000E-06
13 0.000000E+00 0.000000E+00 -3.121340E-06
14 0.000000E+00 0.000000E+00 -1.426400E-06
15 0.000000E+00 0.000000E+00 1.507800E-07
16 0.000000E+00 0.000000E+00 2.283040E-06
17 0.000000E+00 0.000000E+00 4.403640E-06
18 0.000000E+00 0.000000E+00 2.618820E-06
19 0.000000E+00 0.000000E+00 -3.909920E-06
20 0.000000E+00 0.000000E+00 -4.629730E-06
21 0.000000E+00 0.000000E+00 -4.226740E-06
22 0.000000E+00 0.000000E+00 -2.810640E-06
23 0.000000E+00 0.000000E+00 -1.475940E-06
24 0.000000E+00 0.000000E+00 -2.306630E-07
25 0.000000E+00 0.000000E+00 8.773280E-07
26 0.000000E+00 0.000000E+00 9.186020E-07
27 0.000000E+00 0.000000E+00 1.134890E-07
28 0.000000E+00 0.000000E+00 -2.303240E-06
29 0.000000E+00 0.000000E+00 -2.891730E-06
30 0.000000E+00 0.000000E+00 -2.750930E-06
31 0.000000E+00 0.000000E+00 -2.229480E-06
32 0.000000E+00 0.000000E+00 -1.433090E-06
33 0.000000E+00 0.000000E+00 -7.086170E-07
34 0.000000E+00 0.000000E+00 -3.585900E-07
35 0.000000E+00 0.000000E+00 -3.970740E-07
36 0.000000E+00 0.000000E+00 -1.228800E-06
37 0.000000E+00 0.000000E+00 -1.418680E-06
38 0.000000E+00 0.000000E+00 -1.845080E-06
39 0.000000E+00 0.000000E+00 -1.892540E-06
40 0.000000E+00 0.000000E+00 -1.662370E-06
41 0.000000E+00 0.000000E+00 -1.319160E-06
42 0.000000E+00 0.000000E+00 -1.023910E-06
43 0.000000E+00 0.000000E+00 -9.154510E-07
44 0.000000E+00 0.000000E+00 -1.152990E-06
45 0.000000E+00 0.000000E+00 -1.751130E-06
46 0.000000E+00 0.000000E+00 -9.378330E-07
47 0.000000E+00 0.000000E+00 -1.219860E-06
48 0.000000E+00 0.000000E+00 -1.305140E-06
49 0.000000E+00 0.000000E+00 -1.254600E-06
50 0.000000E+00 0.000000E+00 -1.141180E-06
51 0.000000E+00 0.000000E+00 -1.083060E-06
52 0.000000E+00 0.000000E+00 -1.178980E-06
53 0.000000E+00 0.000000E+00 -1.428740E-06
54 0.000000E+00 0.000000E+00 -1.984710E-06
55 0.000000E+00 0.000000E+00 -6.337950E-07
56 0.000000E+00 0.000000E+00 -8.086770E-07
57 0.000000E+00 0.000000E+00 -8.928530E-07
58 0.000000E+00 0.000000E+00 -9.127060E-07
59 0.000000E+00 0.000000E+00 -9.178150E-07
60 0.000000E+00 0.000000E+00 -9.618740E-07
61 0.000000E+00 0.000000E+00 -1.174630E-06
62 0.000000E+00 0.000000E+00 -1.574790E-06
63 0.000000E+00 0.000000E+00 -1.888970E-06
64 0.000000E+00 0.000000E+00 -4.055300E-07
65 0.000000E+00 0.000000E+00 -5.030470E-07
66 0.000000E+00 0.000000E+00 -5.655450E-07
67 0.000000E+00 0.000000E+00 -6.043770E-07
68 0.000000E+00 0.000000E+00 -6.405200E-07
69 0.000000E+00 0.000000E+00 -7.382430E-07
70 0.000000E+00 0.000000E+00 -8.778130E-07
71 0.000000E+00 0.000000E+00 -1.433290E-06
72 0.000000E+00 0.000000E+00 -2.348860E-06
73 0.000000E+00 0.000000E+00 -1.993380E-07
74 0.000000E+00 0.000000E+00 -2.423400E-07
75 0.000000E+00 0.000000E+00 -2.734500E-07
76 0.000000E+00 0.000000E+00 -2.952910E-07
77 0.000000E+00 0.000000E+00 -3.240560E-07
78 0.000000E+00 0.000000E+00 -3.615310E-07
79 0.000000E+00 0.000000E+00 -5.285360E-07
80 0.000000E+00 0.000000E+00 -5.365600E-07
81 0.000000E+00 0.000000E+00 -1.916910E-06
82 0.000000E+00 0.000000E+00 -3.102620E-05
83 0.000000E+00 0.000000E+00 -8.088780E-06
84 0.000000E+00 0.000000E+00 -6.554530E-06
85 0.000000E+00 0.000000E+00 -2.967490E-06
86 0.000000E+00 0.000000E+00 -1.165990E-06
87 0.000000E+00 0.000000E+00 5.222050E-07
88 0.000000E+00 0.000000E+00 3.686480E-06
89 0.000000E+00 0.000000E+00 4.565990E-06
90 0.000000E+00 0.000000E+00 2.465290E-05
91 0.000000E+00 0.000000E+00 -1.515880E-08
92 0.000000E+00 0.000000E+00 -1.430560E-08
93 0.000000E+00 0.000000E+00 -3.032030E-08
94 0.000000E+00 0.000000E+00 -6.294120E-08
95 0.000000E+00 0.000000E+00 -1.051740E-07
96 0.000000E+00 0.000000E+00 -1.718360E-07
97 0.000000E+00 0.000000E+00 -2.087570E-07
98 0.000000E+00 0.000000E+00 -4.611200E-07
99 0.000000E+00 0.000000E+00 -4.233090E-07
100 0.000000E+00 0.000000E+00 -5.650720E-05
101 0.000000E+00 0.000000E+00 4.300920E-05
102 0.000000E+00 0.000000E+00 -2.013980E-05
103 0.000000E+00 0.000000E+00 1.154850E-05
104 0.000000E+00 0.000000E+00 -6.182510E-06
105 0.000000E+00 0.000000E+00 1.919990E-06
106 0.000000E+00 0.000000E+00 -3.624680E-06
107 0.000000E+00 0.000000E+00 -4.986140E-07
108 0.000000E+00 0.000000E+00 -1.931390E-06
109 0.000000E+00 0.000000E+00 -1.609830E-06
110 0.000000E+00 0.000000E+00 -1.202140E-06
111 0.000000E+00 0.000000E+00 -2.086890E-06
112 0.000000E+00 0.000000E+00 -7.945170E-07
113 0.000000E+00 0.000000E+00 -2.158870E-06
114 0.000000E+00 0.000000E+00 -5.501360E-07
115 0.000000E+00 0.000000E+00 -2.318380E-06
116 0.000000E+00 0.000000E+00 -3.609470E-07
117 0.000000E+00 0.000000E+00 -1.880750E-06
118 0.000000E+00 0.000000E+00 -1.794450E-07
119 0.000000E+00 0.000000E+00 -4.222610E-06
120 0.000000E+00 0.000000E+00 -2.133690E-08
121 0.000000E+00 0.000000E+00 -4.595710E-06
$BINDING = ELEMENT
$RESULT_TYPE = Total Ply Thickness(s)
1 8.000000E+00
2 8.000000E+00
3 8.000000E+00
4 8.000000E+00
5 8.000000E+00
6 8.000000E+00
7 8.000000E+00
8 8.000000E+00
9 8.000000E+00
10 8.000000E+00
11 8.000000E+00
12 8.000000E+00
13 8.000000E+00
14 8.000000E+00
15 8.000000E+00
16 8.000000E+00
17 8.000000E+00
18 8.000000E+00
19 8.000000E+00
20 8.000000E+00
21 8.000000E+00
22 8.000000E+00
23 8.000000E+00
24 8.000000E+00
25 8.000000E+00
26 8.000000E+00
27 8.000000E+00
28 8.000000E+00
29 8.000000E+00
30 8.000000E+00
31 8.000000E+00
32 8.000000E+00
33 8.000000E+00
34 8.000000E+00
35 8.000000E+00
36 8.000000E+00
37 8.000000E+00
38 8.000000E+00
39 8.000000E+00
40 8.000000E+00
41 8.000000E+00
42 8.000000E+00
43 8.000000E+00
44 8.000000E+00
45 8.000000E+00
46 8.000000E+00
47 8.000000E+00
48 8.000000E+00
49 8.000000E+00
50 8.000000E+00
51 8.000000E+00
52 8.000000E+00
53 8.000000E+00
54 8.000000E+00
55 8.000000E+00
56 8.000000E+00
57 8.000000E+00
58 8.000000E+00
59 8.000000E+00
60 8.000000E+00
61 8.000000E+00
62 8.000000E+00
63 8.000000E+00
64 8.000000E+00
65 8.000000E+00
66 8.000000E+00
67 8.000000E+00
68 8.000000E+00
69 8.000000E+00
70 8.000000E+00
71 8.000000E+00
72 8.000000E+00
73 8.000000E+00
74 8.000000E+00
75 8.000000E+00
76 8.000000E+00
77 8.000000E+00
78 8.000000E+00
79 8.000000E+00
80 8.000000E+00
81 8.000000E+00
82 8.000000E+00
83 8.000000E+00
84 8.000000E+00
85 8.000000E+00
86 8.000000E+00
87 8.000000E+00
88 8.000000E+00
89 8.000000E+00
90 8.000000E+00
91 8.000000E+00
92 8.000000E+00
93 8.000000E+00
94 8.000000E+00
95 8.000000E+00
96 8.000000E+00
97 8.000000E+00
98 8.000000E+00
99 8.000000E+00
100 8.000000E+00
Sample files (sample.fem and sample.hwascii) are available at <Altair_installation>\hwdesktop\demos\mv_hv_hg\animation\hwascii\.
