::GetCurrentDisplayText
This command gets the current text in an mdlFileName widget.
::model::mdlFileName::GetCurrentDisplayText path
MotionView Tcl GUI
- path
- The full path to the mdlFileName widget of interest. This argument is the return value of the ::model::mdlFileName procedure used to create an mdlFileName.
To get the current selection of the value of an mdlFileName
        widget:
    ::model::GetClientHandle clnt
clnt GetModelHandle mdl
clnt ReleaseHandle
mdl InterpretEntity entCrv Curve crv_0 "\"Curve 0\""
mdl ReleaseHandle
set dlg [toplevel .dlg]
set frm [frame $dlg.frm -padx 10 -pady 10]
grid $frm -row 0 -column 0 -sticky nesw
set data { "2D Cartesian" "2D Parametric" "3D Cartesian" "3D Parametric"}
set cb [::model::mdFileName .dlg.frm.cb entCrv $data -label "Curve type:" ]
grid $cb -row 0 -column 0
set value [ ::model::mdFileName::GetCurrentDisplayText $cb ]
entCrv ReleaseHandleErrors
None.
