::SetDCButtonState
This command will be used to enable or disable the direction cosine button within the mdlOrientation widget.
::model::mdlOrientation::SetDCButtonStatet argFrm argState
MotionView Tcl
- argFrm
- You need to pass the path of the mdlOrientation widget as the above argument, where you need to enable or disable the DC button.
- argState
- You need to pass either true or false to this argument to enable or disable the DC button.
::model::GetClientHandle client
client GetModelHandle mod
mod InterpretEntity mrk Marker mrk_0 "\"Marker 0\"" "" ""
set top [toplevel .test]
set colFrm [frame $top.tmpFrm1 ]
pack $colFrm
set ornt [::model::mdlOrientation $colFrm.ornt mrk]
pack $ornt
client ReleaseHandle
mod ReleaseHandle
mrk ReleaseHandle
::model::mdlOrientation::SetDCButtonState $ornt trueErrors
On successful execution of the command, it will enable or disable the DC button in the mdlOrientation widget.
