::GetCurrentSelectionNodeId
This command gets the node ID for the current selection that is set for the specified mdlTempCollector widget. If the node ID is unavailable or unknown, nothing is returned.
::model::mdlTempCollector::GetCurrentSelectionNodeId path
MotionView Tcl GUI
- path
- The full path of the mdlTempCollector widget that this procedure is being called for.
With a model that contains at least one deformable body (they contain nodes) in the active
        page and window, execute the following script. That script will create a dialog that will
        contain an mdlTempCollector widget that is set to pick “Nodes” and display a message that
        reports the id of the selected node. With that dialog displayed, activate the “Node”
        collector that it contains and graphically pick a node from one of the deformable bodies in
        your active
        model:
    namespace eval ::my_test {
  variable my_node ""
set tl [toplevel .top]
wm geometry $tl 550x100
wm title $tl "::model::mdlTempCollector::GetCurrentSelectionNodeId Example"
grid rowconfigure $tl 2 -weight 1
grid columnconfigure $tl 0 -weight 1
set col [::model::mdlTempCollector $tl.col ::my_test::my_node "Node" "MeshNode" \
  -afterResolveFunc ::my_test::onNodePicked]
grid $col -row 0 -column 0 -sticky nesw
proc ::my_test::onNodePicked {} {
  set id [::model::mdlTempCollector::GetCurrentSelectionNodeId .top.col]
  tk_messageBox -message "Picked node id: $id"
}Errors
This procedure does not generate any errors, it returns nothing if the selection does not have an associated node ID.
