hwIAnimator SetStartFrame
Sets the start frame of the animator.
animator_handle SetStartFrame frame_idx
HyperView Tcl Modify
This command sets the start frame for the animation. This is commonly used when the animation mode is modal.
- frame_idx
- Frame index is 0 based.
To set the start frame of animator to
        "2":
    hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetAnimatorHandle animator_handle
animator_handle SetStartFrame 2;
hwi CloseStackError
Returns (0) if successful.
