hwIH3DExportOptions GetWriteHTML
Queries whether an HTML file will be generated.
hwIH3DExportOptions_handle GetWriteHTML
Tcl Query
Returns true or false, depending on whether writing an associated HTML file is enabled.
If the HyperView Player Browser plug-in has been installed, HyperView can generate an HTML file with the H3D output that will display the H3D file on a web page on any machine.
To check if entity IDs will be
        written:
mySessionName GetH3DExportOptionsHandle option_handle
options_handle GetWriteEntityIDsErrors
None.
