hwIPage SetWindowSyncGroupState
Changes the state of an existing window synchronization group.
hwIPage_handle SetWindowSyncGroupState syncGroupName, state
Tcl Modify
This command changes the state of an existing window synchronization group.
- syncGroupName
- The name of the window synchronization group you would like to change the state on.
- state
- The state that you would like to change to: - True
- False
The following example will synchronize all windows on the current page. Divide your current
        page into the desired number of windows and load a model into each
        window.
    hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle pg [proj GetActivePage]
set numberOfWindows [pg GetNumberOfWindows]
set windowIdList ""
for { set i 1} { $i <= $numberOfWindows } { incr i } {
    lappend windowIdList $i
if { [string length $windowIdList] } {
    set syncGroupName "MyWindowSyncGroup"
    pg AddWindowSyncGroup $syncGroupName $windowIdList
    pgr SetWindowSyncGroupState $syncGroupName true; #activate window synchronization on this group
    puts "Current state  of $syncGroupName : [pg GetWindowSyncGroupState $syncGroupName]"
hwi CloseStackError
This command returns a warning code if the specified synchronization group name does not exist.
