pltIBuildPlotsCtrl SetLayout
Sets the layout.
pltIBuildPlotsCtrl_handle SetLayout layout
Tcl Modify
This command sets the layout when in build plots mode.
    Note: The command
            GeneratePlot must be called to draw the plot with these
          changes.
- layout
- A number representing a layout option. There are a total of 20 different layouts, and a number from 0 to 19 corresponds to each layout. You input a different number depending on which layout is desired.
hwi GetSessionHandle sess;
sess GetClientManagerHandle mgr plot;
mgr GetBuildPlotsCtrlHandle build;
build SetLayout 8;
build GenereatePlot;Errors
Keywords
Tcl
Build Plots
Modify
