Rotate LCS
Use the Manage E-Points tool to rotate LCS on an evaluation point.
- From the SnRPre ribbon, Setup group, click the triangle next to Setup and select Manage E-Points.
- Optional:
From the microdialog, adjust advanced options.
In the modeling window, select the required LCS from
the model.
A microdialog opens. - Rotate in increments using the arrows or enter a value manually.
to open advanced options.
