Create Variability Study
Use the Variability Study tool to examine how squeak and rattle risks are affected by manufacturing variations.
Restriction: Variability studies is only supported for dynamic events and
only one loadcase at a time. You can select which loadcase to include in the study
at export.
From the SnRPre ribbon, Setup
group, select the Variability Study tool from the
Variability Study tool group.
- From the guide bar, select the type of model parameter to include in the variation study.
In the modeling window, select the appropriate model
parameter.
Tip: You can also make this selection from the Advanced Selection dialog by clicking
from the guide bar. -
In the microdialog, specify the lower and upper bounds
for the variation.
Optional: Click
to update the name.
From the guide bar, complete one of the following
options:
- Click
to create the variation and
remain in the tool. - Click
exit the tool. - Click
to exit the tool without
creating the variation.
The variation study with design variables is created for all selected study parameters. - Click
- Optional:
Review and edit the created variation studies and variables.
