OS-E: 8020 Twisted Beam
This example demonstrates a twisted cantilever beam using Explicit analysis.
Model Files
Before you begin, copy the file(s) used in this example to
your working directory.
Model Description
The beam is constrained in x, y and z directions for translational and rotational motion. The end of the beam has a Force load applied. The analysis is carried out for 2 subcases, one with TTERM 0.002 and the other with TTERM 0.005 and DYREL (Dynamic Relaxation), to avoid having any dynamic oscillations by making it static or quasi-static problem. This analysis is performed using OptiStruct’s Explicit via ANALYSIS = NLEXPL.
The material properties are:
- Young's Modulus
- 29E+06 psi
- Poisson's Ratio
- 0.22
- Density
- 7.33E-4 lbf s2/in4
Results
- Element Stresses
Figure 2. Element Stresses Contour
- Displacement
Figure 3. Displacement Contour
