Unable to Extract Desired Fluid Volume
Condition
Certain solid geometry features can sometimes prevent the application from detecting or creating the correct fluid domain.
Remedy
Use the Geometry ribbon to check for rounded features near inlets and outlets and flatten them out. After adjusting the geometry, re-create the fluid domain.
On the Geometry ribbon,
select the tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools.Use the Round tool under the Simplify tool group to to remove rounded features near inlets and outlets. You can also check for gaps in the model, and use Plug to seal them. - Refer to the Simplify tool instructions to make adjustments to your model.
Select Create Fluid Domain to create a new fluid
domain.
The new fluid domain is created.
