Smooth
Use the Smooth tool to smooth mesh geometry.
- If starting from an optimized part in Inspire, first copy the part and then select Paste Without Reference in the Model Browser.
On the PolyMesh ribbon, select the Smooth tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. - Select mesh geometry to smooth.
Use the slider and other options to adjust the amount of smoothing.
Tip:
- The Maintain Volume option is enabled by default. Deselecting this option tends to provide even smoother results, but material may appear thin or be removed entirely in some regions.
- The greater the number of Iterations, the smoother the result will be.
