Radial Bead Pattern
Apply a Radial Bead Pattern
Use the Radial tool to apply beads in a radial pattern.
On the Structure ribbon, select the Bead Patterns tool
on the Structure ribbon.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. -
Select the Radial tool on the secondary ribbon.
Select a surface.
A set of three orthogonal planes appears around the selected part.
Select one of the three transparent planes as the plane of symmetry.
The selected plane is shown in blue.
- Left-click to exit editing mode. Select the part again to apply a second plane of symmetry.
- Right-click to exit the tool.
Tip:
- Two planes of symmetry are supported.
- If you have a bead pattern applied, you can apply a single draw, but not a split draw or extrusion.
Microdialog Options
Use the options in the microdialog to change the type of bead pattern or its placement.
- Apply Bead Pattern: Change the bead pattern from radial to linear or circular.
- Rotate 90 Degrees: Rotate the orientation of the bead pattern 90 degrees.
- Move Bead Pattern: Translate or rotate the bead pattern using the Move tool.
- Align to Part: Align the bead pattern to the selected part(s).
- Align to Global: Align the bead pattern to the global axes.
