Add a Remote Job Server
Add and configure an Altair PBS server to run jobs remotely.
This option is only available for Structures and Print3D analysis, not Motion analysis.
Click the Run group label to display run options.
- Select the Add Server option from the menu.
Enter the Name, Host, and
Port.
Click Save.
A cloud icon appears next to the Run menu when the connection to the server has been established.
- Click the Run group label and verify that the server has been added.
- Set up and run an analysis using the Run Analysis window.
Note:
If Inspire is integrated with Altair PBS Works, you can connect to an:
- HPC Cluster running PBS Professional Workload Manager
- HPC Cluster running LSF Workload Manager
