Run Analysis
Use the Run Analysis window to set up and run a simulation.
Select the Run Analysis
tool on one the Analyze icons to define settings for the desired type of analysis
(structures, motion, print3D, etc.)
- Some of the Analyze tools, such as Motion, feature a quick run
button that automatically runs the analysis with the
default settings. To change the settings, click the
icon
that appears when you hover over the Analyze tool. - The Optimize and Optimize Part tools that appear on the Structures and Motion ribbon work similarly to the Analyze icons. When the optimization is complete, Inspire will open the Shape Explorer rather than the Analysis Explorer.
