Pave
Use the Pave tool to create faces manually on an existing object.
You can also use this tool to:
- Blend two PolyNURBS surfaces
- Close holes in PolyNURBS geometry
- Convert PolyNURBS surfaces to solids
Pave an Optimized Shape
Pave a surface by placing points along the contour of an optimized shape.
On the PolyNURBS ribbon, select the Pave tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. - Select points or edges to define a rectangle. A PolyNURBS surface is automatically created
- To add another face to the PolyNURBS surface, click an open edge on the surface, and then place two more points.
- Repeat the process to pave additional surfaces.
