Rotate Objects
Rotate objects around an axis.
Rotate Objects Around an Axis
Rotate objects around a reference axis with the ability to use a variable.
Select the Move tool, or press
M or T.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. - In the guide panel, select the Rotate tab.
- Next to Part, the Select button is active. Select one or more objects.
Define the Direction:
