Change the Mouse Controls
Change the mouse button and keystroke combinations used to rotate, pan, and zoom so they match other commonly used CAD applications.
- On the File menu, click the Preferences button.
- At the left of the Preferences window, under , click Mouse Controls.
- At the right of the Preferences window, click Same As and choose an application. For example, click HyperWorks to use the same controls as HyperWorks.
- Click OK.
Tip: Inspire supports the 3Dconnexion peripherals. No
additional setup is required, but the device needs to be connected to your computer
before Inspire is launched.
