Preferences: Design Explorer
Define preferences for the Design Explorer.
Design Explorer
| Option | Description |
| Study path | Specify the default location where studies are stored. To choose a new path, click the path, click the Browse button, and browse to the folder you want to use. |
| Design variable deletion warning | Select the checkbox if you want to display a warning message when you delete a variable from the Design Explorer that originally came from the Variable Manager. |
| Save model for each run | Select the checkbox if you want to save the model with updated parameters for each run. |
