Export Geometry and Results
Export geometry and simulation results for use in another application.
Tip: If the other application doesn't convert units automatically, you need
to change the unit system in Inspire before exporting.
Export Geometry
Export the entire model using the Save As command, or export selected objects using the Save Selected command.
Do one of the following:
- To export the entire model, select .
- To export only selected objects, first select the objects, and then select .
- Choose a folder, enter a file name, and select a file type.
- Click Save.
Export an Optimized Shape as an STL File
Export an optimized shape as an STL file, a standard format supported by many CAD systems.
- Click an optimized shape.
- Select or press Shift+F12.
- Choose a folder and enter a file name.
- For Save as type, select STL (*.stl).
- Click Save.
Fit Surfaces to an Optimized Shape
Fit surfaces to an optimized shape, and then save it in the desired file format.
- Right-click an optimized shape, and then click Fit Surfaces to Optimized Shapes on the context menu.
- Click Save.
Export an Optimized Shape to Inspire Studio
Export an optimized shape to Inspire Studio using the Save to Evolve option on the context menu.
- Right-click an optimized shape, and then click Save to Inspire Studio on the context menu.
- Open Inspire Studio.
- On the Inspire tab of the modeling toolbar, click the Optimization Shapes Browser tool.
- Double-click the image of the optimized shape to import it into Inspire Studio.
Export a FEM File to HyperMesh
Export a FEM file to HyperMesh using the Export button on the Run Optimization window.
- On the Optimize tool, click Run Optimization.
- Click the Export button.
Choose a folder, type a file name, and then click Save.
Inspire writes the FEM file to that location, using the currently active unit system for the model.
