Apply an Environment from the Render Library
You can choose from a variety of preset environments. If you can't find exactly what you want, you can choose something similar and modify it. You can also reuse a custom environment that you have previously saved.
On the ribbon, select the Rendering tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools.The Render Library is displayed. -
Select the Environments tab.
Double-click an environment.
The environment is applied to the scene.
