Adding and Deleting Macros
Macros are added to a workspace via the Data Source Library. Access to this library is also provided by:
clicking on the drop-down arrow of any column in your table and then selecting Column List
clicking on the drop-down arrow of any column in your table and then selecting Macros > Add or Edit Macros
clicking Add or Edit Macros
in the Change History panel
Adding text macros
Click on the Data Source Library
icon in the Data Prep Studio toolbar.The Data Source Library displays.
Click Add Macro... as shown below.
From the options that display, select TEXT MACRO.
The Edit Text Macro dialog displays
The Sample Values column shows combinations of text formats that you can clean.
Click the drop-down icon located to the right of the Text field in the Sample Values column and then select a data-prep operation to apply to your text field.
You can apply the following changes to text columns as macros:
Change Type
Details
Case
Make Proper Case
Make Lower Case
Make Upper Case
Clean
Remove Leading & Trailing Spaces
Remove Consecutive Spaces
Remove Specified Characters
Remove Non Alphanumeric Characters
Remove Numeric Characters
Remove Alpha Characters
Extract
Starting from Left
Starting from Right
Using Position & Length
Between Start & End Text
Insert Text
Redact
Replace
Ditto
Nulls
Blank Values
Using Find and Replace
Using Position and Length
When you have finished selecting the changes you wish to apply to your text columns, click OK.
Adding numeric macros
The steps necessary to add numeric macros to your workspace are identical to those described above, except that you should select NUMERIC MACRO in Step 3.
You can apply the following changes to numeric columns as macros:
Change Type |
Details |
Compute |
Format |
Replace |
Adding date/time macros
The steps necessary to add date/time macros to your workspace are also identical to those described for how to add text macros above, except that you should select DATE/TIME MACRO in Step 3.
You can apply the following changes to date/time columns as macros:
Change Type |
Details |
Format |
Replace |
Deleting macros
All of the macros you have created display in the Macros list of the Data Source Library.
To delete a macro, select the Delete
icon located to its right.
Close the Data Source Library when you are finished.
