Creating a Table from a Selection
Allows you to create a new table based on the columns and rows you highlight in an existing table. Note that tables created from this operation, which is essentially a copy function, cannot link back to the original table and are NOT refreshed when the original table is refreshed.
In this example, we highlight a subset of an existing table:
Selecting Create Table from Selection creates a new table with the following columns and rows:
Initially the new table is named <table>n, where <table> is the name of the source table, and n is a counter that starts at
To rename the new table refer to Renaming a Table.
