Export Design Window
The Export Design Window allows you to view or edit existing exports.
To access this window, select Export Design on the Export View ribbon. Note that different panels and tabs display depending on the source view and output file type.
Table View
This panel displays if you select an export that uses a table as its source.
Setting |
Description |
Export Name |
Displays the name of the current export. |
Select Filter |
Selects the filter you want to apply to the table or summary. Select the All Filters option to apply all of the available filters or the No Filter option to apply none of them. If you choose the All Filters option, specify the desired Automatic Naming setting:
Sort Order |
Applies a sort order to the data you are exporting. |
Summary View
This panel displays if you select an export that uses a summary as its source.
Setting |
Description |
Export Name |
Summary |
Selects the summary that you want to export. Select the "All summaries" option to export all of the available summaries. |
Automatic Naming
Specifies how you want Monarch Complete to name the export:
Drill State
Specifies the desired drill state:
Measure |
Specifies either one of the following options:
Split |
Check Each distinct value of the first key makes a separate file or table to split the summary export according to each value change in the first key (i.e., the leftmost one). If you choose this option, specify the desired Automatic Naming setting, either "by files" to have each distinct value of the first key make a separate file, or "by tables" to have each change of it make a separate table. |
Select Filter
Applies filters to the summary. Select the "All filters" option to apply all of the available filters or the "No filter" option to apply none of them. If you choose the "All filters" option, specify the desired Automatic Naming setting, either "by files" or "by tables". |
Sort Order |
Applies a sort to the summary. |
Report View
This panel displays if you select an export that uses a report as its source.
Setting |
Description |
Export Name |
Selected Reports [All] |
This setting shows all reports contained in the table being exported. Select the checkboxes of the reports you want to add to the export file. |
Output View
This panel displays the various options available for specific export types.
Field |
For Export Type |
Description |
File Name |
All |
This field displays the name of the export file. Modify it by supplying your desired file name or selecting an existing file using the Browse button. |
Export File Type |
All |
This field is prepopulated with the export file type you selected from the Add Export dialog box. |
Table Name |
Displays the current name of the table. You can assign a new table name by entering it in the field. For Microsoft Access exports, you can set a password for your export file by selecting the Password checkbox and then clicking the Edit button. In the Edit Password dialog box, assign and confirm your desired password and then click OK. |
Show Tables |
When exporting a table to a file that already exists, this setting allows you to see the destination file’s existing tables and columns and select the table to which the data should be appended or overwritten. When a table from the Show Tables dialog is selected and confirmed, the name of the selected table is inserted into the Table Name textbox and the current content of this box is overwritten. |
When output files exist |
All |
Provides options for when a file of the specified name and type already exists in the export location. Select one of the following options:
NOTE: Exports in *.hyper format can be published to Tableau Server. Select the Publish to Tableau Server checkbox and provide the necessary details in the fields that display. These fields are described in detail here. |
When output tables exist |
Tells Monarch Complete what to do if the output table already exists.
General/Advanced Tab |
The General tab allows you to modify general export settings (e.g., Export Location, Table Name). For table exports, the Advanced tab allows you to modify the following settings:
For summary exports, the Advanced tab also shows the following options, in addition to the Digital Signature and Certificate options:
Export Locale |
This setting specifies which type of encoding to apply to the export file. The accepted encoding types are Western, Japanese, Simplified Chinese, and Traditional Chinese. To use the default setting, choose Use current system locale. |
Require a password to open the document |
Select this option to set a password for the export file. Click the Open Password button to set the desired password. |
Restrict access to document contents |
Select this option to manage access to the content of the export file. You can restrict or allow printing, context extraction, editing, and annotation for the export file. To apply any of the restrictions to the export file, you must set a password by clicking the Permissions Password button. NOTE: If you choose not to specify PDF file permissions, users will have full access to the export file. |
Encryption Type |
This setting specifies which encryption type to apply to the export file. The following options are available:
