Report View
Report View allows you to work with reports. From Report View, you can also launch Report Design to create or edit report templates.
The Report View interface has the following elements:
Panel |
Description |
1 |
Ribbon Displays all the tools you need to work with a report. Refer to the Report View Ribbon Quick Reference. |
2 |
Allows you to search for and/or select a specific report to view. |
3 |
Report Viewer Displays the currently selected report. When templates have been defined for a report, the parts of the report |
The Report Selector Context Menu
Right-clicking on the Report selector displays a context menu that will allow you to perform the following operations:
Reopen a file
Close a single or multiple reports
Quick print a report
Export a single or multiple reports, the corresponding table, and its associated summaries
View file information dialog (includes details on file path and name, size, last modified date)
The Report Viewer Context Menu
When you open a report and right-click on your mouse in the Report Viewer, a context menu displays. This menu will allow you to:
Run Report Verify
Copy text
Copy as table
Search for a record
Find in table
Add, edit, or remove bookmarks
Define a new template
Edit field or table properties
Zoom to fit
Print
Print preview
Export the report to a PDF or TXT file
Change the encoding applied to the report file
Launch the Report Design window
