Template Editor
Use the Template Editor to define a data extraction template. The template editor has the following elements:
| Element | Description |
| [ 1 ] Action Bar | Displays all the tools you need to define a template. Refer to The Template Action Bar for details. |
| [ 2 ] Trap Line | Allows you to define your trap. Position you cursor over a character in the sample line and then select a trap. |
| [ 3 ] Sample Line | Displays a sample line from the report. This sample line is used as the basis for defining the trap. Select a sample that best represents the particular line type (e.g. report detail or report header) of the report. |
| [ 4 ] Report Sample | Displays the pages of the current report. Use the scroll bar to view other report pages. |
To display this editor:
      Select the Report tab to go Report View.
      Select Report Design on the Report View ribbon.
