Define Temperature Dependent Properties
Define density, thermal conductivity, and specific heat capacity with respect to temperature.
- In the menu bar, click .
In the dialog, select a material to apply temperature dependent
properties.
Density, thermal conductivity, and specific heat capacity allow temperature dependent input via material database.
To add temperature curves, select Add Density-temperature
curve, Add thermal conductivity-temperature
curve, and/or Add specific heat capacity-temperature
curve.
Note: Non-zero values should be set for temperature independent thermal conductivity, specific heat capacity, and density along with temperature dependent properties to complete material definition. The curves are utilized only if the Use temperature dependent properties option is checked in thermal transient setup. Otherwise, the non-zero nominal values are used.
- Define the temperature curve(s) in one of the following ways:
Method Process Import from CSV - Click Import CSV.
- In the File browser, select the desired .csv file and click Open.
Create manually - Click Add row.
- Enter the temperature and relevant property values. At minimum, two points are required.
The results are plotted in the XY graph in the dialog. You can use the scroll wheel to zoom in, the left mouse button to pan, or the Refit button to reset the graph.
CSV File Format
Density-Temperature Curve
- CSV Fields
- Temperature – Numerical value
- Example File
Temperature,density26.85,8930
Thermal Conductivity – Temperature Curve
- CSV Fields
- Example File
Temperature,conductivity1.136,238.168
Specific Heat Capacity – Temperature Curve
- CSV Fields
- Example File
Temperature,capacity17.647,862.245
