Imported Flux
Apply flux from an external comma separated values (.csv) file. Available only for thermal steady-state analysis.
Note: For 2024.1, imported pressure is not supported for composites.
- In the Project Tree, open the Analysis Workbench Workbench.
On the workbench toolbar, click
Flux →
Imported Flux.
Browse to the desired .csv file in File Explorer and click
Open.
The imported loads are mapped at points/parts specified in the .csv.
The .csv file contains one header row and one or more additional data rows.
Imported flux .csv file format fields are as follows:
- ID (optional) – Alphanumeric value used to identify a specific point.
- X, Y and Z – Numeric values.
- Flux – Numerical value.
- Part_ID (optional) – Numerical value. ID of the part to map the flux. Mapping fails if the part with specified part ID is not present at the spatial location defined in X, Y and Z.
- Part_Name (optional) - Alphanumeric value. Name of the part to map the flux. Mapping fails if the part with specified part name is not present at the spatial location defined in X, Y and Z.
Note: If both Part ID and Part Name are defined, Part ID takes
precedence.
- Example CSV File
ID,X,Y,Z,Flux,Part_ID,Part_Name 1,216,417,40,100,15,square tube 2,216.975,417,40.0961,100,15,square tube 3,217.913,417,40.3806,100,15,square tube
Note: Temperature change in an imported file follows the input units set in SimSolid. Spatial location values follow model
units.
