Modify Results Plot
Adjust the display attributes for the results plot.
- On the Project Tree, open the Analysis Workbench.
On the Analysis Workbench
toolbar, click
Results plot.
In the drop-down menu, click the desired plot.
The Legend dialog will open, and the chosen contour plot will appear in the modeling window.
Control the contour bounds.
- Under Image, set the contour colors.
Click
(Show deformed shape contour plot) to show deformed
shapes in the modeling window.
Change deformation scale factor.
Click
(Change max deformation).
- In the dialog, clear the Default check box and either adjust the slider, enter a scale value into the text box, or use the arrows to increment the scale factor as desired.
- Optional: Clear the Default check box and enter a scale value of 1.0 to set deformation to true scale.
Click
View/adjust the Animation.
