SS-T: 4001 Buckling Linear Analysis
Perform buckling linear analysis on an I-section beam.
- Prerequisites
- Some features used in this tutorial are only available in the SimSolid Advanced version. Switch to Advanced to complete this tutorial.
- Purpose
- SimSolid performs meshless
structural analysis that works on full featured parts and assemblies, is
tolerant of geometric imperfections, and runs in seconds to minutes. In this
tutorial, you will do the following:
- Learn how to create buckling linear analysis in SimSolid.
- Model Description
- The following model files are needed for this tutorial:
- buckling.ssp
Open Project
- Start a new SimSolid session.
On the main window toolbar, click Open Project
- In the Open project file dialog, choose buckling.ssp
- Click OK.
Create Structural Linear Analysis
Structural
analysis→Structural linear
Create Immovable Support
In the Analysis Workbench, click
Immovable Support .
- In the dialog, verify the Faces radio button is selected.
- Select the Add tangent faces checkbox.
In the modeling window, select the face shown in Figure 2.
- Click OK.
Create Buckling Force
Force→Force/Displacement.
- In the dialog, ensure the Faces radio button is selected.
In the modeling window, select the face shown in Figure 3.
Figure 3.
- For Z direction Force, enter -100 N (compressive load).
- Click OK.
Create Buckling Linear Analysis
Structural Analysis→Buckling
linear.
The new analysis (Buckling 1, linked to Structural 1) appears in the Project Tree under Design Study 1 and the Analysis Workbench opens. - In the dialog, select Structural 1.
- For Number of modes to find, enter 6.
- Click OK.
Edit Solution Settings
- In the Analysis branch of the Project Tree, double-click on Solution settings.
- In the Solution settings dialog, for Adaptation select Global+Local in the drop-down menu.
- Click OK.
Run Design Study
Solve all analyses in the design study.
- In the Project Tree, select Design study branch.
Click Run All Analyses
- In the Solver Manager, verify all analyses are selected.
Click Solve.
SimSolid runs all analyses in the design study branch. When finished, a Results branch for each analysis appears in the Project Tree.
Review Results
Review the results for Design Study 1.
The results show Part 1 buckles first at a load factor of ~17.5.
To obtain the approximate buckling load, multiply the buckling factor by the
buckling load.
In this case, 17.5 × 100 N = 1750 N buckling load.
