System Requirements
Operating system, hardware, software and memory requirements.
Windows
- Operating System
- Windows 10 (64-bit)
- Memory
- 8 GB of RAM (32 GB recommended)
- Graphics Hardware
- OpenGL 3D graphics accelerator compatible with OpenGL 3.3 or higher
- Video Recording
- Any graphics card can be used when recording animated GIFs. MP4 video recording is only supported for NVIDIA GPUs, beginning with the Kepler generation and with a minimum graphics driver version of 378.66.
Linux
- Operating System
- RHEL/Oracle Linux 8.4 (64-bit)
- Memory
- Graphics Hardware
- OpenGL 3D graphics accelerator compatible with OpenGL 3.2 or higher
Supported Compilers on Windows Platforms
TCC is the default compiler provided for Windows. Some use cases require the installation of a third-party compiler. The following are the supported compilers for the Functional Mock-Up Interface (FMI), Modelica components, and C-code generation.
| Compiler | FMI Export | Modelica Support | C-Code Generation |
| Microsoft® Visual Studio 2022: Community, Professional | Yes | Yes | Yes |
| Microsoft® Visual Studio 2019: Community, Professional | Yes | Yes | Yes |
Supported Compilers on Linux Platforms
GCC is the default compiler provided for Linux. Some use cases require the installation of a third-party compiler. The following are the supported compilers for the Functional Mock-Up Interface (FMI), Modelica components, and C-code generation.
| GCC | Yes | Yes | Yes |
Required Development Tools for Linux Platforms
The installation of development tools is required for Linux platforms to compile C code. The proposed commands will ensure that the required development and build tools are installed for GCC and G++.
| Linux Platform | Installation Command |
| SUSE 15 SP 2 |
| RHEL/Oracle Linux 8.3 | or
Supported Versions of Altair MotionSolve and Altair MotionView
View table of verified compatible versions of Twin Activate with MotionSolve and MotionView.
Supported Versions of Altair Flux
View table of verified compatible versions of Twin Activate with Flux.
