Modelica Library
The standard Modelica library is organized with these functional palettes: User Guide, Electrical, Magnetic, Mechanics, Thermal and Sl Units.
Importing Modelica Libraries
Import Modelica blocks for use in Twin Activate models.
Important:
Imported libraries must be compliant with the MSL 3.2.3. In addition, libraries must be valid Modelica packages, <package>.mo, and include the standard Modelica folder structure.
- Save a desired Modelica library to your local system.
From the menu bar, select .
Alternatively, select , and select the option to Create a new library from a Modelica library.
From the Library Creator dialog that appears, for Modelica library
path, enter the path to the library that you want to import. For
Activate library path, enter the path where you want
to save the library, and click OK.
The selected Modelica library is converted into an Twin Activate library and saved to the specified directory. Once imported, the library is available in the Palette Browser and remains so for future sessions unless uninstalled.Important: Imported libraries include unique IDs that are included in the block definitions. When sharing a model, you must also share any imported libraries that the model references.
