Map OML Class Object to Python Class Objects
Compose supports bi-directional bridge between OML and Python with default datatype mappings. This guide shows how to expand this mapping to class objects.
OML Class Object
Say you have an OML Class object called OmlCircle with _radius as its property and methods like GetRadius, SetRadius, and GetArea are defined as below:
classdef OmlCircle
properties
_radius
end
methods
function self = OmlCircle()
self._radius = 0;
end
function self = OmlCircle(radius)
self._radius = radius;
end
function radius = GetRadius(self)
radius = self._radius;
end
function SetRadius(self,radius)
end
function ar=GetArea(self)
ar = pi*self._radius^2;
end
end
end
Python Class Object
Say you have a Python Class Object PyCircle defined as below:
class PyCircle:
def __init__(self, radius = 0):
def GetRadius(self):
return self._radius
def SetRadius(self,radius = 0):
def GetArea(self):
import math
return (math.pi)*(self._radius**2)
pycircleobj=PyCircle(9)
OML Class to Define the Mapping
Implement OmlPythonBridgeCircleImp, which inherits the OmlPythonBridgeInt class and defines
necessary methods for the successful mapping of objects.
- Create a class to map OML objects to Python objects. This OML class has to inherit from OML class "OmlPythonBridgeInt."
- Define Methods to:
- Check if Python variable can be imported to OML.
- Check if OML variable can be exported to Python.
- Get OML variable imported from pythonvarname.
- Export OML variable omlvar to Python with the name as the value of pythonvarname.
- To register the OML class name, call the OML
function registeromlpythonbridgeext. For example,
registeromlpythonbridgeext(‘add’,‘ClassName’)
classdef OmlPythonBridgeCircleImp < OmlPythonBridgeInt
methods
function obj = OmlPythonBridgeCircleImp ()
obj = struct();
end
% check if python variable can be imported to OML.
function status=CanImportPyVar(self, pythonvar)
status = false;
analysisusingpythonbegin()
_is_circle_obj = ['_is_circle_obj' sprintf('%.0f',tic)];
evalpythonscript([_is_circle_obj '=False']);
eval_status = evalpythonscript([ 'if isinstance(' pythonvar ', PyCircle):' _is_circle_obj '=True']);
if eval_status
status = getpythonvar(_is_circle_obj);
evalpythonscript(['del ' _is_circle_obj]);
end
analysisusingpythonend()
end
%check if OML variable can be exported to python
function status=CanExportOmlVar(self, omlvar)
if strcmp('OmlCircle',class(omlvar))
status = true;
else
status = false;
end
end
%to get oml variable imported from pythonvarname
function out=GetPythonVar(self, pythonvarname)
status = true;
outval = '';
try
if ~ isstr(pythonvarname)
error('pythonvarname must be string.')
end
_py_radius_var = ['_radius' sprintf('%.0f',tic)];
evalpythonscript([_py_radius_var '=' pythonvarname '.GetRadius()']);
_oml_radius = getpythonvar(_py_radius_var);
outval = OmlCircle(_oml_radius);
evalpythonscript(['del ' _py_radius_var]);
catch
status = false;
end
out = {status, outval};
end
% to export oml variable omlvar to python with name as value of pythonvarname
function status=ExportToPyton(self,omlvar,pythonvarname)
status = false;
try
if ~isstr(pythonvarname)
end
_oml_radius = omlvar.GetRadius();
exporttopython(_oml_radius,_py_radius_var);
status = evalpythonscript([pythonvarname '=PyCircle(' _py_radius_var ')']);
catch
%do nothing
end
end
end
end
registeromlpythonbridgeext('add', 'OmlPythonBridgeCircleImp')
Call PythonBridgeOMLCommands
When Implemented, you can use OML Python Bridge commands to import or export the class objects.
In the Python Command window:
pycircleobj=PyCircle(9)In the OML Command window:
omlcircleobj=getpythonvar('pycircleobj');
exporttopython(omlcircleobj,'pycircleobjfromoml') Note: After you execute the clear all
OML command, you must rerun the OML files to make
OML classes available in the interpreter.
