Specifying the Major Axes Range
Specify the range for the major axes.
On the Surface
contextual tabs set, on the Display tab, in the
Axes group, click the
Axis settings icon.
Figure 1. The Axis settings dialog.
Select the axis that you want to modify.
- To modify the grid range for the horizontal axis, click Horizontal.
- To modify the grid range for the vertical axis, click Vertical.
Under Ranges, select one of the following:
- To automatically determine the grid range, select the Automatically determine the grid range check box.
- To specify the grid range, clear the Automatically determine
- In the Maximum value field, enter a value for the upper limit of the graph.
- In the Minimum value field, enter a value for the lower limit of the graph.
- Click OK to apply the settings and to close the dialog.
