Defining PCB Current Data from File
Import printed circuit board (PCB) current data from a PollEx radiated emission interface (.rei) file to create a PCB current data definition. Use the current data definition when defining an equivalent source.
On the Construct tab, in the Define group, click the
Field/Current Data icon. From the drop-down list
select
Import PCB Current Data From File.
Figure 1. The Import PCB Current Data dialog.
- In the Current data (*.rei) file field, browse to the file location of the .rei PCB current data file that was written out by PollEx.
- In the Label field, specify a unique label for the PCB current data.
- Click Create to define the PCB current data and to close the dialog.
